What have you ordered? *Detailing*
Gally
Re: What have you ordered?
Emo clothes probably. :eek:
Anyway there are dos packages awaiting me at my Manor. I'll update later! :)
You've just reminded me. I ordered a fecking blue Angry Bird toy for my misses (both big fans) as just a wee present - still not farking arrived! Must have been three weeks :(
Gally
When do you want me to detail it for you! :eek:
Where from JD? Somewhere in far east Asia?
Sheeting with the open hose y0.
Just emailed Angry Birds. Response straight back.
"If you've ordered anything from this site after Jan 11, it won't ship until March". Plastered all over the website as well :(
Ali
  V6, Trackhawk, GTS
I'm going to need a whack of new stuff for my annual detail!
Me and the GF's Valentines present to each other
Gally
I'd blow one of them just to spend a day there.
  White Sti Hatch
LOL! Boys got a point! I thought you were boarding today! WTF you doing on CS
Only went up for a half day seeing as i couldn't see 5 ft in front of me, plus managed to rip of my splitter on the way into the car park too :(
  STEALTH RAIDER
I would only use a glaze for filling swirls but your right they do look good. Id sooner lay down a good strong sealant and then top it off with a wax. especially after a full machine polish.
If your paintwork is covered in bonded contaminates which it will be then they will transfer to your pad/s when polishing, which will then marr the f**k out of your paintwork. Ill admit ive done it before, polished a car without claying and I really struggled and had to keep washing my pads every pannel because they were covered in s**te. Especially the bottom half of the doors and front quater pannels.
Its not a huge job atall. I wash the car, drag it into the garage and then dry the car. I then go round the car claying it with last touch as a lube or any quick detailer I have lying about (so long as its not synthetic) and just wipe each pannel dry with the towel after claying it. Last touch (and other detailers) are a good drying aid and can be used to spritz a pad before polishing. Yes, it is a must. I clay atleast once a year, usually every 6 months. Your last stage products such as wax or sealant will bond better too.
A machine polish will take you a good 4-5 hours I rekon, maybe less if youve done it before, claying takes a short period of time if you work quickly.
Why cant you use synthetic detailrs to clay? Synthetic has the highest lubricity out of all detailers. Plus it can be diluted and still be used as a clay lube. As a bit of a tip, when youve finished claying a panel, dont wipe over the area with a mf that is bone dry as bits that arent wet can still cause friction and marr. Your best bet is to wet a mf and ring it right out till its moist, safer pickup ;)
I agggrededdeded. But I always wash after claying.
  Not a 320d
Some synthetic detailers add protection and whats the point. That said last touch still adds a bit of wax apparantly. I dont know if that last piece of advice was aimed at me or not but generally i spray down the pannel and clay block, clay the pannel then wip eover to dry it witha drying towel.
  172 RS Ph1
Because most clay bars cant stand the polymer formula and will slowly start to pick up less contamination and fall apart (at least thats my experience :) )
leedsboy
  Bean 182 + E70 X5
Ordered an Autobrite HD Foam Lance along with 5L of their Magifoam earlier. Also get 500ml of their Super Snow Foam free :approve:
This is definitely the last stuff I buy for a while.
  STEALTH RAIDER
All depends what clay bar your using and i use it diluted which hasnt the same effect ;). If you only use a clay bar once as i do then you will prob not even see the effects. I know a lot of people who use shampoo which is reknown for recking them!!
More German Applicators. Four to be precise. Because I love them. It make-a me a-happy.
My cleaning session never happened. Damn scottish weather. I'll get ripped into it when I'm back on dry land!
