bullets removal - how do i take them off please
DO NOT use a screw driver. Push up the bullet from the bottom at the square end (rear of the car) Then when the cip releases push down on the bullet same side until the clip releases this stage is a bit tricky. Now the scary stage Pull up from the square end, you think the bullet is going to snap in half but it doesn't
Good Luck !
