Will this fit my 1.2 16v 2003 billabong
Well that is for a Clio Mk3, where as your's is a Clio Mk2, so i would say no it would not fit. Anybody else feel free to say otherwise.
shape..... major factor lol. there is a document on here which shows each mk and ph but i do not know how to access it im sure someone will be along and link it
Mk2
Mk3
That's the difference.
If I bought a standard backbox and added a tailpipe. ( welded on ) would I notice a noise difference ?
Do you mean an exhaust trim? If so then no you won't, nothing you'd notice anyway.
If you want noise then you'd have to go for an aftermarket exhaust and/or do something with the air filter (induction kit)
jesus christ what is it with this place these days.
surely you dont need to be an engineering guru to work out that simply adding a bit of extra pipe to an exhaust isnt going to make it any louder? or is it just me?
i didnt change it, its standard, but no you wont tell a difference in sound its just a bit of pipe, the sound is to do with the exhaust system silencers, pipework diameter and type of metal used. no tailpipe is going to make a difference in sound!
it appears they take a normal dci106 clio backbox, chop off the tailpipes and bolt some fancy ones on!
Could you tell a difference in sound
FLOL!
Open Bonnet , find air filter , open housing at one side , lift so gap of a few mm appears , close bonnet , drive around in billabong with faster sounding car.
