HELP! Aftermarket steering wheel
Nickw88
  BMW F82 M4
Right, I'm a little stuck and need some help. Currently sat in my car feeling perplexed...
So far I've removed the wheel and have these wires in front of me. I have an OMP boss kit and also the airbag bypass kit but don't know what to do with them...the connector plugs are too large to fit through the gap in the boss so haven't been able to fit that yet.
Do I literally just cut the connectors off? Is there another way? How do I wire them back up later?
Thanks!
daveski
The connectors in my phase 1 fitted through the hole in the boss fine. I know that doesnt help but are you sure they wont fit? I wouldnt cut them off tbh, especially if you plan on putting the standard wheel back on
Nickw88
  BMW F82 M4
Thanks for the reply. I've managed to squeeze them thru and got the wheel on now so at least I can drive it!
I'll fit the airbag bypass and horn kit tomorrow but don't know how to wire those up either, there weren't any instructions and I'm not mechanically/electrically minded! Now I've got my serv, airbag and traction control lights on :(
Any ideas?
DrR
  VW Golf GTD
I thought it was pretty well known the connectors don't fit through the hole in the OMP boss'
Nickw88
  BMW F82 M4
Well tbh I didn't research it particularly well, although I've got them all through bar one which I unclipped, took apart and then soldered back together. Obviously my problem is what to do with the wires now to make everything work properly :S
