Clio PH1 'V' reg grande 1149cc clutch......
  RenaultSport clio 182 Cup
Hi guys,
Just a quick query as I'm useless with car mechanics.
Recently purchased the car, the bite point is quite high an it's sometimes difficult to get into 1st and 2nd gear. Is this a sign the clutch is due for replacing?
Any help appreciated.
Regards
Ben
Martin_172
clutch bite is high as standard, struggling to get into gear is most likely a worn engine mount, my guess being the lower one (do you have loads of movement in the gearstick when coming on and off throttle?)
  2007 clio dynamique
I have a 2007 mk3 and i find it hard to get into reverse , i have movement in the gearstick when letting of the throttle could this also be a worn mount ?
Sent from my HTC Wildfire using Tapatalk
Yeh there is quite a bit of movement in the gearstick when coming off the throttle in 2nd and 4th. Easy to sort myself?
  MK7 Fiesta TDCI ZS
the bolts attaching my lower gearbox mount (dogbone) mount were loose on my car which is identical to yours and sorted out the shaking and shudders in 1st gear, and the selection issues. I just nipped them up and its been fine ever since. Was easy to get to with the car jacked up :)
sbridgey
  disco 4, 182, Meglio
My brother learns in a MK3 which is brand new and apparently he has to really slam it to get it into reverse :S
