Windscreen Washer Pumps
Car  Flame Red 172
Alright chaps,
I've had problems with my washers since I picked up the car a few weeks ago - trickle from the front, nothing out the rear.
I tried swapping the jets for the mist type from Citroen and it made no difference so since then been looking around for a replacement pump and cheapest I could come across was £10 second hand.
Anyway, long story short, I did a speculative search on ebay for washer pumps local to me but excluded "RENAULT" from the search.
First thing to pop up was this:
http://www.ebay.co.uk/itm/CITROEN-W...&otn=3&po=LVI&ps=63&clkid=3148035023050846250
Popped round this morning and compared to one I removed, looked the same. Got it home and fitted it - perfect and for £5.99! It also looks like they don't charge postage either?!
Anyway, I hope this helps someone out and saves a couple of quid for you!
do they do the mist type sprayers plus the pump? where is the pump located and was it all easy to change?
Anyone know if the cup washer pump is the same as 172/182 (obviously the cup does not have headlamp washers)
Windshield washer pump is the same. Headlight washers have a seperate pump. Reservoir is different on a cup (low spec tank).
Cheers mate, my front screen jets seem to pulse rather than spray. Strangely though my rear jet has started to work on its own after 3 years of not working.
