Yep it does. as for the gearbox on this car i'd like to know what box has been used as if a phase 2 none cup box was used then getting a speedo drive to work won't happen.lol fair enough, there doesnt seem to be a definate answer where ever I look, maybe some good ol' bodgin is needed?
I think the ph1 172 runs off the ABS sensor if Ive been informed right so maybe getting to run off this some how?? Im sure where theres a will theres a way!
Just seen your not a member so you cannot see I've posted the info from the post above this.It wont let me see that post for some reason?? quite annoying, any clues as to what it was saying?
Much appreciated!![]()
There are ph2 models with the jc5-130 gearbox fitted without the speedometer sensor , that is the same box as in the 182 , so the speed signal is taken from the ABS .Yep it does. as for the gearbox on this car i'd like to know what box has been used as if a phase 2 none cup box was used then getting a speedo drive to work won't happen.
Yep the cup uses the speedo sensor box as i has so abs sensors. What I meant with my my quote was that if the diff is figtted to a proper cup etc box with speedo sesnor why wasn't if sorted. If its ben fitted with a none speedo sesnor box why was it and fixing it won't be cheap.There are ph2 models with the jc5-130 gearbox fitted without the speedometer sensor , that is the same box as in the 182 , so the speed signal is taken from the ABS .
But as far as I know , the 172 ph2 CUP doesn`t have ABS , so no speed from the ABS on the ph2 CUP .
