Getting a wobble only under acceleration (dip the clutch / throttle off and it goes away), rather than being through the steering, it actually shakes the car side to side between about 30-50mph in any gear - more pronounced under high rpm.  Then same above 80, feels ok 50-80 though.  Bearings feel tight, ARBs and TREs look fine, driveshafts/boots both look ok.  Looks like passenger side spring may be half a coil short, so could do with replacing, but could that be causing the problem?  Was thinking it could possibly be a mount on the way out - there's a lot of side-to-side play in the gearstick when in gear.
Any thoughts, CS?
			Any thoughts, CS?
