ITB's are generally fairly well sealed anyway, its probably carbs that you are thinking of which are more of an issue, but thats all ancient history now anyway, no one with a brain uses carbs anymore if they can avoid it, lol.
There really is no point to running ITBs on a low boost setup though, its just not going to give you any advantages and will increase the cost significantly.
Unless you just want to do so cause it sounds good down the pub? lol
There was something they had to seal in to get them to work not sure what it was though some thing to do with boost leak.
As I have already told you, most ITB's are fairly well sealed anyway, about the only place you are likely to lose any boost is down the spindle of the throttle shafts and thats no more or less of an issue really than on a single TB.
You seem to be trying to remember something you think you read once, I'm talking from experience of multiple cars I have mapped on ITBs and a turbo, there arent any real issues in doing it, but there also are very limited gains to be had.
ND, what throttle bodies specifically were they talking about? (ie what make)
Do you have a link to that thread, I havent been on this forum long so am not familiar with it.
According to that article, that car isnt on bodies as such, they have done it the same way that I did with just using the throttle body outer shells and no plates with a shared plenum and a single throttle, this is the one I did the same thing with:
Its only still ITB's if you have one plate per cylinder, not one shared plate.
Thanks, it was a great build until the engine block split
Had steel crank, steel rods, forged pistons, touring car spec head, block all line bored etc, but with regards to the block itself it turns out that at around 600bhp or so they just cant cope and crack, quite common knowledge now and we have ways around it, but we didnt know that at the time I did that build (was about 7 years ago)
600 bhp thats a epic build pity about it splitting the block. What have you been able to push one to now if that was 7 years ago?
There are ones out there now at 900bhp+ using the ZLet block instead which is easier to re-enforce at the point that my one failed (the 900bhp+ ones are not done by me, ive moved onto other engine types now and the only c20let's ive been involved with recently have been 400-500bhp or so trackday cars rather than really chasing the numbers)
Ive not personally turbo'd a clio engine yet, although I did support MWM with some mapping on their turbo project as they were trialling a different ECU (Mtech V4) to it than the ones they normally use (Omex) which I have a lot more experience of mapping than Mike and Jack and we do quote often help each other out with various projects.
Clio engines are fantastic, not just the F4R but also the older F7R like in my mk1, but I am fed up busting gearboxes so have gone honda engine and box for the clio turbo I am building at the moment.
Our other mk1 is staying F7R on a custom inlet I made a couple of years ago to replace the ITBs I took off, which is along the lines of an RS2 manifold though, this is it with the plenum cover off, I did that with a view to turboing it originally before I got so pissed off with the boxes! :
My mrs has just ordered an RS2 for our 172, thats probably as far as we'll go with that one for now as she is using it as a daily, I might turbo it at a later date though and go with the Audi gearbox conversions that are being worked on at the moment by various people, as that then makes the clio engines viable again, i might not have gone honda in the first place if there was that option when I started the other project, but TBH I love honda engines anyway so am quite happy with that.
Could you not have made one of these for the Mrs car that look's good doe's it work aswell or better than the rs 2
We could have done, but she likes the look of the carbon fibre, and the RS2 is already there so pointless spending ages creating something my self when it can just be bought so easily.
Not sure how my F7R one would compare as not ever had an RS2 on the same engine as they dont fit (head is totally different) I would imagine the RS2 will out perform it though, its had a lot more development, i just made that one for something to do on my own car, not as a commerical product so its not had the same R&D that the RS2 has had, its a fantastic product.
The carbon looks nice rs2 looks well developed never seen one in the flesh but some good feed back about it on here
