Harnesses with Trophy Recaro's
What harnesses do I need (specific type?) and how do I mount them to the Trophy Recaros?
All help appreciated :)
Surely any 3 or 4 point would do the job? 4 point would be prefferable if you have a cage, 3 point would be easiest if you don't.
Usually mount should straps on rear top mounts (i.e. where you'd attach a rear strut brace) and use the standard points for lap belts (inside mounted to subframe/seat, outside mounted to original points at base of door)
I don't have a cage and also have no idea about harnesses as I've never looked into them, so it's all new to me :o so basically 3-point harnesses would do the trick?
A 3 point harness will do the trick but it's always safer to have a cage incase of a crash.
Do you mean the harnesses won't work as well if they're mounted to the seatbelt mounting points, or do you mean in case I rolled it?
Harnesses keep you bolt upright, so if you roll it the roof will push against your head. With normal seatbelts you'd lean forward.
Wouldn't go through the loops. I've got 4 points on mine and use the two seatbelt bolts (b pillar and buckle) for the lap straps, and the buckle bolts and iso bar bolts for the rear straps.
