Quikshift
Car  clio 172 phase 2
Hey guys ive been thinking about buying a quick shift for my 172 as the gear change isnt very good as it should be feels a bit loose . Ive been looking at this link.
http://www.cliosport.net/forum/showthread.php?562442-Fitting-Short-Shifter-Kits
Basically that shows you how to remove the stick without removing the oem gearknob . Say i was to cut the oem gear knob of surley it would just pop through the gear stick housing . If you see what i mean .
Tell me what yOu think . I hear theres a good kit available from a guy on here yano isit?
Obviously Tony and Jay are more experienced mechanics, but what I would say as an amateur is that I managed fairly easily with just normal garage tools reading through the instructions and with the car on axle-stands. (I re-wrote the instructions for Yanoo so they read a bit better in English now.) As Tony suggests give Yanoo a PM, he is really helpful and the kit is a nice bit of... kit. I also went for the Stiff-Shift (will become obvious once you’ve contacted Yanoo) – well worth doing and at the same time.
