Automatic xenons no longer working
Car  Ph2 172 (black bean)
Just had the bulbs changed on the 172 and now they don't automatically turn on. Work fine by manually turning them on. I'll be speaking with the garage tomorrow but just thinking could it be something they haven't attached when they change the bulb??
Any ideas?
Turn the key to the last position before the car starts then flick your lights on and off twice then you should hear a beep.
Pretty sure that's how you do it
Now not sure if this is linked but the washer jets on the lights aren't working anymore, I've re-activated the auto lights but the washers are no longer working, any ideas?
iirc there are two pump for sprays, but I can't remember if it's one for front, one for back, or one seperate for the lights. Are the windscreen ones working? could be a blockage. Are the washer ones leaking?
Keep your finger on for over a second to activate the headlight washers i believe, don't do quick flicks
Its one pump for the headlights and one for front and rear screens.
Check theres voltage to the pump.
