Help/Advice De-Chavving my "sound-system"
Car  (s)Low Dynamique
Ok so had my car for over a year now, and in that space of time I've grown up a bit mentally. I'm in the process of de-chavving my car, tints are coming out, and I want to get rid of my horrific twin edge 1800w sub from halfords, that takes up my whole boot.
I plan on buying a small sub, more than likely less than 1000w, and 'maybe' installing it into a stealth-shelf (parcel shelf) to keep boot space decent.
I also want to uprate all 4 door speakers (not sure on the w really)
Obviously I'll need amp(s) to power all this, need help on how many amps and what wattage(s) I'll need.
Finally, if possible, I'd like to purchase all the above from the same brand!
Could somebody possibly put together a bit of a shopping list for me? Or explain some of the options that I have?
Also, would a sub work on a stealth shelf?
I'm very confused thinking about it all haha, many thanks in advance x
Focal Access 1 Active Slim Fit 25cm
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_76 8875_langId_-1_categoryId_165748
Focal Access 1 Active Slim Fit 20cm
http://www.halfords.com/webapp/wcs/s...k&iozone=PDPz1
Infinity BASSLINK
http://www.halfords.com/webapp/wcs/s...egoryId_165748
All these subs are designed for underseat installs or slim boot applications.
If you want the best quality products and installs go on:
www.fourcars.co.uk
Find you're closest dealer to be impressed...
I currently have HERTZ products -ENERGY range, top quality products
http://www.briancarsounds.com/produ...z-ebx-f25-new-250mm-4-ohm-500w-ultraflat.html
Getting that tomorrow, sounds the part, and will fit on the rear seats, need to remove the isobar though.
Obviously with the other speakers, you'd probably want a component front set and a coaxial rear set. (6x9's?)
I recommend HERTZ products to anyone :) honestly sound immense, quite expensive though, but trust me you won't be disappointed.
I hope that helps you out matey :), oh by the way there are loads of fake focal products out, safest to go from halfords.​
