Ball Joints
They will do the trick. I bought 2 of the Lemforder ones as iirc they make them for renault, citreon etc.
Ah I wasn't aware of that - is there much difference between the two as I don't paying the bit extra if necesarry.
I fitted mine myself the other day, the Lemforder ones from Euro have all new bolts and new hub nut too.
Not a bad job.
Any help on removing this:
You'll need to grip the nut on the other side, as obviously its spinning the whole bolt/nut.
I removed the nut expecting the bolt to come straight out.
The thread has burred on the bolt and i cant get thr nut back on the thread :(
You should get a new one with your new ball joint, therefore you can try turning it and tapping the other end with a hammer. The hole is not threaded so if you do damage anything it will only be the ends of the thread on the old bolt.
