Whats wrong with your car right now??
Car  172 berg, Fabia VRS
As title, mine needs a new battery, 2 new tyres and a clutch really soon!! What does your car need right now??
Need a new outer passenger side cv boot that's it. I've pretty much replaced everything else on my ph1 lol.
Catalytic Converter is falling to bits, all the bits are rattling round the centre section of my yozza, makes it sound well...... Horrible
Hid bulb needs replacing.
Starter motor needs replacing.
Two rear tyres.
Driver side wing mirror glass needs fitting.
New alloy wheel bolts.
This could be a good thread to merge with " im buying a renaultsport clio what should i look out for" lol :)
Leaky sump gasket,
tie rods and track rod ends need replacing,
one of the CV boots is shredded,
it's been 5 years since the cam belt was replaced,
so this year it'll need belts, pullys, tentioners, and dephaser done.
The seats are really hard to slide back and forth,
the headlights need wet & dry sanding,
ABS & TC lights have been coming on and off for years,
alloys are curbed to f*ck,
and for some unknown reason my ipod randomly cuts out for a second every now and again but only in the car,
I'm sure there's more but I can't think of them right now.
I love the thing though, it puts a smile on my face every time I drive it,
so just like a super fit bird that's a bit high maintenance.......you'll put up with it's failings for a good ride.
L-reg volvo - 200K miles - nothing wrong with it
Dynacup - Sam stole a load of bits from it and hasn't given them back
phs 1 172 - its a bodyshell
02 volvo - battery + 4 tyres
V6 - no comment
Ka - battery + rust + lower arms
Ka - not sure where it is actually!
Needs a wash, and I need to get a new exhaust bracket fabricated so it doesn't droop down so fcuking low
leaky sunroof
manifold too close to a coolant pipe
rust on arches
dents all over
needs respray
need new N/S brake drum
need to repair bumpers
need to replace NS window rubber as its split
need to buy front seats and rear bench
need to modify alluminium door cards to fit
needs battery charging or new battery
need to fit new bonnet
needs oil change/filter change/new spark plugs
needs new heater matrix
needs coolant flush n replaced
dash needs to come out to pipe in incar boost controller, reconnect blower pipes
electric windows dont work
rear window needs to come out to fill some rust and an awkward dent
think thats all off the top of my head
Jeez davedreds thats expesive lol, probably buy a decent 172 for the cost of fixing/replacing parts plus labour
Rear caliper needs replacing
Alignment is way out
New caliper is on its way and alignment is booked in :)
haha, mainly bodywork tbh, only things i have to buy wont cost alot, and all will be done by myself, so just time consuming more than anything
Only the sump gasket, tie rods/ends and cam/aux belt service are worth spending money on this year.
The rest I can live with, apart from needing a new gearbox last year, i've not really had any problems with it in 5 years of ownership.
1. airbag light on due to airbag ecu internal fault (got a new one but its off a cup so can't be used as says wrong config when plugged on)
2. 2 rear tyres
3. needs new rear pads and discs
4. cambelt aux belt and dephaser
5. need a spare key as only ever had one
6. engine mounts/exhaust mounts
7. clutch
8. i keep finding stone chips on it
9. need to sort out headlamp lenses
think thats it
Nowt, flew through last MOT with no advisories, just serviced, all good. I hate things not right so worn, loose etc things get fixed asap.
Ah, has a tiny dent on the bonnet, & a bulb out on the clock display :rasp:
Filthy, it's showing 16.1mpg and the wipers squeak.
That's all.
rear caliper is seizing. (4 new calipers coming)
headlamps scaled up. (thinking of xenons)
doesnt like 1st gear (new gearbox coming)
nowt that'll stop the smile on my face!
cambelt aux belt and dephaser, + service.
engine mount
wheels refurbing
bonnet has ripples on the edge by the grille - 2nd hand bonnet when i find one close enough to be @rsed collecting (hint hint)
valet & good polishing
SELL THE MERC!!!!
strut turned around, raised front left, passenger seat needs tightened up to stop rattling.
New discs and pads all round soon as I just want to.
