Fitting Polybushed dog bone mount
yeecup
Car  mk8Fiesta ST,172 cup
Quick question, is this the right way up when I fit this to my ph1?
Yeah not looked at the standard one yet just bought this and read conflicting things on here.
You have it the right way up with the thicker bit at the top,you definitely need the washers though.
Cheers Ross.
everyone saying the thicker bit goes to the top should shush. It's a ph1 dogbone not a ph2 so the bolt goes through the bush horizontally not vertically. What you need to do it try it on the car and see which way it lines up, one way will be easy, the other will be too far over
Ditto, i havent fitted mine with washers, i think its only the ph2 one which needs them.
This. It will only fit one way. Takes 5 mins to fit :) also mine has no washers and is fine!
Cool, just need to put it up on the ramps now when I can be arsed
