Gearbox Failure (Help Needed) Please
Car  1.2 daily +172 ph1
Hi all over the last 3-4 months i had a project in my spare time.
had a ph1 donnor car picked up for £600 with dephaser problem and the owner didn't have the funds to fix.
Had a ph2 Non sport sitting around for 2-3 years rotting away.
Anyway decided to go ahead and make tack car results follow.
(ph1 stripped) http://i661.photobucket.com/albums/u...t/2D793E1F.jpg
(non sport stripped) http://i661.photobucket.com/albums/u...t/B05A2BCC.jpg
(all up and running) http://i661.photobucket.com/albums/u...t/7476918C.jpg
sorry about pictures only ones i had available.
Right had a track event at Rockingham on the 23rd of January and car performed very well In dry condition with out an issue.
now the car started to wind in 5th gear after the event when letting of the throttle :@.
Had an event on 8th feb and was getting car ready for this then completely lost 5th gear
then whilst trying to resolve this problem in all gears was hearing something scraping along the floor looked and Nothing (Was the Gearbox)
decided to try draining gearbox oil and refilling with new oil just out of interest then whilst on axle stands to diagnose the situation had it turning over in the air with me under the car.
And then car decides to lock it self in 3rd Gear would not come out of gear at all. (video under car) http://www.youtube.com/watch?v=Omtkr...0PEOWY89Yxk9gs
MY Questions (My the engine Is from A ph1 sport 172 X reg F4R
1. What is my gearbox code as gearbox is filthy and carnt locate it.
2. What gearbox options do i have? anything think a little more low ratio?
3. I would prefer warranty on the box so i know its in fully working order - OR Would it be best just to get refurbed?
Hope someone can herlp thanks
You need a Ph1 172 box or 172 Cup box.
Cup box has slightly lower ratios I believe.
Get yours rebuilt. Agency Transmission in Worcester are spot on (mind that i came over from Germany to bring them my 'box). Reasonable priced if you pay cash aswell.
JC5 129 is the Ph1 code.
JC5 130 is Ph2 172 & 182.
Not sure what the 172 cup code is..
Would a JC5 129 be write fitment aswell as speedo fitment?
Had a quote for £350 plus 50 delivery for a JC5 129 (18 month warranty)
Or would it work out cheaper rufurbing box?
Depending on whats needed. Agency only replace whats worn unless you ask otherwise.
we paid £180 for ours to be done a while back. Had new bearings, seals, selector fork, 3rd/4th syncro and planet gears in the diff
Worst bill ive heard of from Agency was about £350 and that was to replace almost everything including the main shaft
