Car Rigs?
No idea on earth how I'm going to transport a 10ft pole in a Clio, but hey ho.
You should cut it in half, then get a piece of pipe that has a slightly wider diameter, you can then use the wider piece as a sleeve that the two smaller ends go in to and then lock/clamp together some how... if you know what i mean.
I've got two 6ft pieces coming as well, so I'd be able to do that fairly easy TBH. Good thinking batman.
Pics. WOuldn't trust it for Video.
IMG_4649 by feirny, on Flickr
IMG_4648 by feirny, on Flickr
You taking pics or video?
I really need to have another attempt at video.
I still need to make a gliderail, then I'll do another vid. Might even do one for CSS this year.
So you have two suction mounts holding the small bar that runs over the large pole, then a further clamp/suction mount actually holding the bar to the car?
For now, yes. I'll be getting some more clamps for the 2 other suction mounts, then I'll be able to control the height a little better.
Sorry for all the questions mate. Could you get some close ups of the mounts and clamps? Just so i know what I'm looking for when I purchase them. Again sorry for all the grief.
Tagged you on FB mate, I'll get a shot later of it all in situ.
I like the editing part more than anything else.
I need FCP.
Editing's what I was always best at. Not done it in years properly though, plus my laptop doesn't run Premiere Pro well. Aquired a copy of Premire Elements the other week which isn't too bad, not had aproper play yet though!
Ok so after pestering Greg for a bit of info I also did a bit of research on TalkPhotography and it returned two excellent threads. Happy viewing.
There a few people that make their own and it's very cost effective.
The bases are a big pole. Aerial poles work quite well.
3 x superclamps
2 x suction cups
a magic arm and then a wire to help support it.
Lots more info in these threads
http://www.talkphotography.co.uk/for...d.php?t=323196
http://www.talkphotography.co.uk/for...d.php?t=374627
As above really, mine needs a little tweaking, and some wire to stabilise it. Thought I'm pretty much there, and works well.
IMG_4720 by feirny, on Flickr
Ignore this one really, as I'm getting more clamps to use instead of this, but works for now.
IMG_4721 by feirny, on Flickr
And an out take I like.
IMG_4725 by feirny, on Flickr
