Tappy engine after spark plug change
If you raise the idle slightly with the throttle to where it was before, does it still sound tappy?
If the engine tries to idle too low that can make it sound rough.
Ok ngk's ordered for less then a tenner. Ill pick up a new ignition coil monday (even if its not the problem, my ocd takes over and it needs to match)
For the time being old plugs are in (bosch super 4) and its still tapping away.
I have an odd coil, I really don't think it's to do with them or the plugs, maybe injectors
Are you 100% sure it is coming from the block & or head itself, and not a reverb from elsewhere..
