clio 182 help???????
Car  182 cup
hi im new to the forum can anyone help me my engine managment light is on traction control light is on and service light is on i plugged it in to computer and only thing it said was flywheel sensor so i changed tha engine managment light went out went down street and come back on and said flywheel sensor again and it was a new part and it never picked nothing up for traction light any ideas?????
You will have a couple of problems here: Firstly the TC and SERV light will be a fault somewhere on the ABS system so you will need to connect to that, not the ECM, to diagnose this fault. Secondly what were the actual fault codes/description and did you replace the flywheel sensor with a genuine Renault part or did you see any fault with the wiring itself?
Finally, does the car have any trouble starting, does it run/drive okay?
Mick
Mick
I bought the part from motor factor and some times it cuts out and no prob at starting
