182 rear exhaust hanger, 1 or 2?
Car  182 FF, A6 Avant
My exhaust hanger has collapsed and it's on the piss now. Going to order one from Renault, but I seem to recall reading that there are two hangers? I've looked quickly under the car and the one between the tail pipes is foobar, is there another that it's worth me replacing while I'm at it?
Theres 4 on the back box if its the standard sytem and normally 3 if aftermarket..
And there is 1 on the centre section
5 all together for a standard system
4-5 on an aftermarket system
Ah... sounds like I need to have a proper look!
The one I've noticed is the large one with the rubber in a metal frame.
I've got a Miltek on my car if that makes a difference.
iirc the miltek runs the same 5 as the standard system..
The other(s) are located behind the back boxes above the rear beam
They are two rubber hangers in a metal frame at the back, two little rubber hangers in the middle which are within 3 inches of each other and then one little rubber hanger halfway down the centre section, You can buy a kit off the internet for around £30 which contains all of them and also the spring loaded connection between the cat and down pipe which may be worth a change
The cat/down pipe connection was new not long ago when I refitted the cat.
Do you have a link to the mount kit for £30?
Chances are you only need to do the two furthest toward the back which hold the tail pipes up.
Could always use sockets/pipe to bodge the hanger, as the Renault ones are pretty soft!
£25 for the rear one from the dealer up in Manchester. Will try Reading at the weekend.
