Trafic 140dci
Just picked up a Sabelt Taurus seat and don't know what side mounts to get, are they all universal fitting?
Thanks
Lewis
Thanks
Lewis
What have you got in at the moment? As you need to make sure that whatever you get will be long enough to bridge between the two welded in seat rails. Those will work but the issue with them is is that they need to be fitted with the fixings facing outwards from the seat rather than under the seat and I doubt there is enough width in the clio to do that. Just depends which shell size the Taurus is as they do 3 sizes of seat and they vary massively as I have found out when buying my ones (The wider it is the less space you'd have to fit those mounts you linked above) Otherwise though those mounts look ideal
Ahh okay, Yes they will fit the holes on the seat but that specific type get bolted to the car from the side of the seat rather than under it and I don't think the clio shell is wide enough to allow for it. I have tried to find photos to show what I mean but can't find any![]()
Surely it doesn't have to fit that way round? The seat i've got is only a Medium anyway, and i have no seat rails currently so they are going to be welded Bespoke to suit so we can sort something out i'm sureCan you see the bottom of this picture the mount doesn't go under the seat but comes out to the side? I just am unsure the car shell has enough width to allow for this.
