More turbo questions!
Car  Ly Megane 230 F1
I know everyone will say do a search etc but i have honestly been searching the past 30/45mins trying to find answers to my questions and ive had no luck!
The questions i have are..
MANIFOLD QUESTIONS.
Does a megane 225 turbo manifold fit directly onto a 1*2 head? or is there tapping and drilling needing done? (nevermind this question now,i now know that its a direct fit)
Is there enough room at the back of the 1*2 engines for a 225 manifold and turbo?
TURBO QUESTIONS.
Am i right in saying that the 225 uses a td04 turbo and that these turbos are water cooled? if so...does anyone know what model of td04 as i know there is variations of this turbo.
Again..is there enough room to accommodate this turbo at the back of the engine?
DOWNPIPE QUESTIONS
Will the downpipe from a 225 fit in the space at the back of a 1*2 engine? if so...is it far off from been on the same path of the current exhaust?
Have done more searching on a Meganesport forum and found that they use a TD04 14t turbo. so one less question.
The downpipe fouls the master cylinder on a clio. The reality is you'll need to drop your compression ratio as well, for the work involved you may as well use a garrett set up as the potential upgrades for the future will be a lot higher
There is space for the exhaust manifold and turbo but there isn't for the down pipe so some modification is needed for the brake master cylinder.
I've never fitted the megane inlet to the 1*2 head but from what I heard it doesn't fit straight on. You will need to lower the compression ration anyway so you'd be as well fitting the 225 head to your block. You'll also need to get an oil return for the turbo.
if you were going to all the trouble of fitting a turbo would you not want to fit a bigger one than a standard megane turbo to start with, seems pointless
I know all the work needed to fit a turbo and I know what the bhp limits of the td04 are..I am just curious as to how much of the standard megane f4rt parts you can use with serious custom work. But thanks for your replys about the downpipe
I have the head, inlet and exhaust manifolds, turbo, pistons, crank and rods from a 225 and the block and box from a Clio.
Still to get the electrics done so not running yet but it all goes together.
are you sure the 225 crank will work ?. if your running a clio box you will be running a clio clutch and fly which i dont think with bolt up to the 225 crank
I'm not clued up on these engines but I no from the Vauxhall forums when people convert to turbo they use the na crank as it's stronger and a na inlet cam.
Why would a na crank be stronger when it is subjected to less torque?
Doesn't make sense to me.
I have no idea. Guys on the vaux site have been converting na engines to turbo rather than using a turbo engine to start
My bad, the na crank is lighter but equally as strong as the turbo and that's why its used
Sure its not just easier to use the na crank on a na engine and it's strong enough for the purpose. Dought it's stronger as for a car manufacturer to do that does not make sense.
thanks for the input guys..
I now know that the megane exhaust manifold will fit directly to the head and there is room for the turbo.
The model of turbo used if any one is curious is the td04 14t.
if i can source the megane parts at a reasonable price i might consider a low boost conversion.. ive written up a list of ever part i need just pricing bits up at the moment.
if i go down this route im far away from doing the internals lol...
Id be after a low boost conversion around 6/7psi..ive calcalated it to cost me around £700 with a fare bit of help from a mate who is a pipe welder/fabricator to make up the downpipe and intercooler pipes.
My brother had an a3 1.8t and it has just been written off so he stripped it of all the extras. So i can get a few parts like air filter with relocation pipe,intercooler(its a universal ebay one but still works none the less),boost gauge and a dump valve really cheap.
Mapping may double that.
My dads cousin owns a garage in inverness and he does live remapping so again its not to much of a problem. My brother was running an intercooler,decat,induction,throttle inlet pipe and my brother seen good gains after the remap and he was only charged £200. I know mapping is expensive as ive asked wallace performance in Aberdeen for a price as i was curious and they wanted £495!. Im quite lucky with the people i know that can help me out...its just finding the money to start it thats the problem lol
I have mentioned this on another thread, how many Clio turbos have they mapped on a standard Ecu? Remember the Ecu is not designed to work with boost and it takes a lot of work to get it right, get it wrong and you engine won't last long.
i know ive read as many threads on turbo 1*2s that i could find on here. I know there has been clios that have had failure from been turbod but theres also been ones that run fine. If i was running a lbt around 6-7psi and the mapping was good i see no reason for the engine not to last long unless i was constantly thrashing it/not looking after it i.e servicing etc/been an idiot and turning the boost up past what people call safe psi on standard internals.
