RB 182 Cup
				I have been looking on Ebay and no luck. Can I get these through Renault?
			http://www.k-tecracing.com/show_product.asp?id=2143&catid=&appid=2&pic=3 If I order these could I get the Renault badged centre cap from Renault?
my mate got some from local scrapyard 100 all in with brand new tyresSounds like your be getting a good deal if some are available from the scrap yard they won't know what their worth.
also i dont know what the fascination is with trophy turini's their just the same as the cup turini's but have a higher offset so they sit further in the arches?
I always thought the trophy offset meant they sat slightly wider than the cup offset? Which is why i was after a set really. If this is the case then cup alloys for me!
From a handling point of view, most people seem to prefer these clios to be as wide as possible, so the 172 cup ones are probably a better option, but bare in mind the comments that the rear arches may rub.
Renault have no delivery date for them, had a set on order for over a year now!
Although the needs to be as wide as poss, as people say. For what I want I am better off for trophy alloys? I do not want the rubbing on the rear geez, so the trophy ones won't do this will they?
discontinued from Renault now i was told the other day
Thought they had to keep spares available for 10 years?
Trophy is wider from disk to disk iirc, so the higher offset wheels are to correct that so they don't end up sitting further out.
So 172 cup wheels on a trophy would be widest combination and trophy wheels on the 172 cup would be narrowest.
Hopefully someone can confirm or deny that as I'm not a trophy expert so may have remembered wrong.
Just a note that you'll be needing ET45 Turini's for the 182, so you'll def be needing the trophy turini's. Bide you're time on these, a set will come along.
