Temperature Sensor
Car  1.2 Clio Dynamique
Someone kicked off my passenger side wing mirror and I have replaced it and since replacing it I have lost the temp read out on my display. I have also lost the function of moving the mirror with the switch. I have checked the fuses and they are fine. The other wing mirror works and need some help
Check the wiring loom in the door and confirm/deny power and function signals
I have the same problem with my temp display (sometimes it shows 60 degrees, now its nothing), instead of making a new thread, how do you check with the multimeter?
When you fitted the replacement mirror, did you plug the electrics from the mirror into the wiring loom in the door. Or its possible your replacement mirror is a non temp, non electric moving one.
Its the correct mirror and I have plugged the electrics into the mirror
