Clio 200 Gordini headlights
Car  V6 Clio
My 2010 Clio 200's front lights are really not great !
I'm sure when I got it I couldn't get Zenon's but they said it was fitted with the Renault equivalent ?
I've had the car taken to South Africa for use there, it's terrific there as I'd specified it with the Cup suspension and the roads are fantastic ! Smooth and twisty, Heaven.
Round the fantastic mountain roads I can use there it's brilliant !
Until it gets dark when the headlamps are dangerous they are so dim !!
How can I improve them ?? Any ideas ??
Ta in advance.
Are you saying you don't know if it has Xenons? Whack up a pic of them and we'll see.
If it hasn't got Xenons, Osram Nightbreaker + are good bulbs.
Renault did not offer xennon light on RS 200. Sure of it as I wanted them when buying the car.
IIRC the cornering lights come with projectors. Then you can retrofit a HID kit.
The cornering lights
I don't think you could spec these on the cup.
Thread HERE might be helpful.
Thanks,
no there was no option for Zenon's when I ordered it so I shall look into someone to retro fit your suggestions of HID kits
6k is the colour temperature of the bulb. The higher the number, the bluer the bulb. Don't go higher than 6k, which is white with a tiny bit of blue.
55w is the power of the kit - 55 watts. You can get 35 watts or 55 watts, choice is yours. 55w is hotter but brighter.
