Jap Box
				Got a few small bits to fix shortly, hopefully their all cheap but looking the one up it seems to be the water pump.
1. The speedo dies randomly, revs, temp, fuel etc all work fine but the speed needle just drops to 0mph. Could this be a speed sensor or some sort?
2. When stationary pushing the gearbox into 1st, 3rd or 5th you can rock the entire gearbox it seems. Am I right in thinking gearbox/engine mounts are shot? Nothing happens when going into reverse, 4th or 5th. Havent tried rocking it when moving incase it causes some massive problem.
3. This has only happened once so it might just be a one off.
After doing 10miles I noticed the temperature needle had gone straight from the middle level to the red, which caused the STOP and tempterature light to pop up on the dash. The headgasket isnt gone as this has been checked, which is why im thinking it could possibly be the water pump thats going? To sort it I just put the heaters on full at hot so it cooled down to the right temperature again, it hasnt happened since.
Thanks for any help
Thanks for any help
