172 cup hasn't been great really, and im after people's advice of what i should do, especially traders...
I understand when you buy a car if you overlook certain bits its your own fault really, which is why I have had it a month and spent money on it but now i am just f**ked and I have only driven about 300mi!
I want to know if i can ask for a refund if i have changed parts on the car (i.e. skoda splitter, wheels) and I have had it a month but done less than 400mi
heres a history so far:
26/05/12 bought from trader in doncaster for £1700, 86k, cambelt done, had been sat for a bit so brakes were rusty and handbrake needed doing (bartered down) .
Heard tapping noise after a pace down a country road, stopped and checked it over, after switching it off and speaking to the bloke to say i was bringing it back he said "engine is sound just had cambelt done, give it a few days, needs a good run and it will be fine." After turning it over again tapping was gone so i just agreed that it must need a good run. (thought it was down to VVT trigger sticking)
2/06/12 changed wheels to 172 wheels £200 (from chav chrome 17" and sold them £100 on fleabay)
started running a little rough, bought new ignition leads £50 (cured problem)
18/06/12 replaced two front tyres £140, handbrake cables £60, skoda splitter £12
20/06/12 Went to Renault Harrogate to replace rusted catch under warranty and a check over.
on the check over found compensator valve was seized and d/s driveshaft boot was insecure, number plate light not working.
also They didn't replace the catch as the spring was missing so couldn't do it under warranty..0_o?
25/06/12 While turning off a main road power steering failed, after coming to a stop car idled and stalled, upon restarting engine tapping noise was back, like metal being hammered. Picked up and towed by RAC who said it may be the timing or "something expensive" :dapprove:, upon browsing the forum i believe its Hydraulic tappets that have gone
As i've said above really after advice from people on how to approach the trader (or even if i can being I have altered parts of the car)
thanks in advance
thanks in advance
