Camber bolts for ktec/raceland coilovers??
Dan
  172 track thingy
I have fitted a 2nd hand set today (big thanks to Aldo for helping me out!) but theres no camber bolts, what camber bolts can I use and are best with these coilovers as I will need to get it tracked up soon??
Thanks
Dan
Dan
  172 track thingy
Eibach do camber bolts available most places dude . Ktec, kam , ebay
Ye I thought about them but I thought I also heard they won't work with these coilovers, could be very wrong as its only "what I heard" so was just seeing if anyone else had used any other camber bolts on here
aucky
  N
I think Matt had a problem with these coilovers and eibach bolts. Can't remember how he got around it in the end though.
They should have their own machined bolt to fit in the slotted hole. Terrible camber adjustment on the cup 60mm fitting racelands as they are drilled out, think this is slightly different to the 172 though.
Ktec stock these and their own set which is very very very very very very* (*I could keep going) similar. I would have thought that they cold help you out.
Edit. Completely misread the fact you mention KTEC in thread title, so you are clearly aware of the similarities and my post above is now rather pointless lol.
Coby.
  XC60-R.......V40-R
Did you get anywhere with this?
Need some Camber bolts for a set I have sitting in the garage.
