For the anal amongst us, the new i5 booting up before the error message:
Screen looks much bigger and better, but then the sacrifice is the size of the device, obviously.
Please don't tell me you thought that video was real Scutch? :clown: The screen on the 'iphone5' is glued on, visible at 30 seconds! lol
Great, so I will need new docks, connectors and leads.
Ah well, never mind, this topic's been done plenty of times already.
Unless you buy the handy adapter, which should be made available at launch. The new 19pin connector is all to do with EU regulations I believe, so not solely down to Apple being sneaky and greedy. Although I'm sure that may have something to do with it.
Nope, the EU regulations are to do with a common charger interface, Micro USB.
This isn't micro USB, and therefore will still require an adaptor.
This is most likely partly about removing the historical crud from the connection (think all the way back to the very first iPod) but probably more likely about saving money. This new connector looks far cheaper to manufacture, saving a few pence here and there when you're shipping in the volume that Apple are soon adds up to a lot of cash.
Headphone socket at the bottom makes me Abit sad
Makes more sense than having the wire hanging over the screen when you're trying to use it.
Indeed. That was/is annoying as f*ck. But easily sorted by simply snapping the cable.
Hopefully compatible with the iDA-X305S! New cable in order for the car
I'm sure there will be an old to new convertor wire, will give a bit of extra length too I suppose.
It's not moaning for the sake of it, I'd bought into a technology and have a £300 dock I use to charge my phone at night and play music on, if I can't use it I'll be pissed.Docks etc is moot. Just people moaning for the sake of it.
You'll get a new cable/charger with the phone. That's all you need. If you bought a dock previously then it wasn't going to fit regardless of the port change.
You don't HAVE to upgrade and if you bought any Android/Windows phone then they wouldn't fit either.
Exactly, it's a new phone. Were Apple going to stick with the same, mahooosive, dock connector forever?
It's progress. Short term pain for long term gain.
