Uprated brakes 1.2?
can you get uprated brakes for a 1.2? only really looking at fronts and rear drums are fine.
I'm not sure if you can get uprated discs calipers pads etc for a 1.2 ph1
if you can what would be the best option?
if i was to try and do a 172 front brake conversion, what would i need? hubs?
Is there any need? K tec do a big brake kit for the 1.2s.
If i was you i'd just get new disc's/pads from G172 on here who would supply brembos.
Leave a bigger gap between you and the other car in front. As said above put new discs and pads on and get the fluid changed too
I wouldn't bother changing to big brake conv IMO. Just get a decent set of pads & discs on it & change the fluid. Job done.
