Got some LED sidelights to go in but couldn't be ars*d getting the jack out and changing them. And a new tax disk holder as the current one is retardedly large.
Had my windscreen repaired today so that's one less thing off my mind. Got my sidelights fitted which turned out to be quite awkward as the holders were just completely welded. Again, just something to tidy up the front end as the yellow looked sh*te against the Xenons.
R56 020 by Arctic_182, on Flickr
Much better..
R56 021 by Arctic_182, on Flickr
Also gave it what will probably be the final clean of this year as it is just far too cold to be cleaning cars. Such a rewarding colour to clean up, and gets a fair bit of attention when it is clean. Attention in a good way though, not like the 182 where every c*nt and his dog just wants to race.
R56 025 by Arctic_182, on Flickr
Decided to get some Eibach springs to reduce the arch gap, but I've got a knocking from the front passenger side now. Changed the droplink and the ARB bushes but it hasn't cured it. Depending on what it gets diagnosed as and factoring in the potential cost I may go for coilovers.
Lol guess so. Hope you sort it mate.
Looks good, I've never really been into Mini's but they are starting to grow on me, why did you choose to sell the Clio for the Mini? Just fancied something different?
Now that would be telling.Oh really? Do tell....
Yeah, went in under warranty on Tuesday and was diagnosed as a gearbox mount which will be fixed by them on the 8th (fast service ftw).
Wouldn't start after work last night, and when I did get it going it was misfiring like a good 'un and kept dying. Managed to get it going and it's been ok since. In all honesty I think it is starting to get coked up again. The previous owner had a de-coke done at around 48,000 miles iirc. Then it could be done under warranty, but they have now taken it out. I think the fact this car has already had it done could stand me in good stead if I try to get another one out them, which I will be doing come the new year.
I need an oil catch can for it too, which again will be after christmas as from now on I probably won't do more than a couple of hundred miles in it.
The coking issue isn't something you have done on a regular basis bud, depending on how the car is driven some people don't suffer from the issue. Short trips ect makes things worse.
Also an oil catch can will prevent this. It does sound like your HPFP maybe on it's way out again covered by warranty.
Nowt wrong with ours, sounds like you've bought a lemon.
Hope it gets sorted.
I was messing mate, I know of the original owner from various MINI forums and he appeared to take care of it.
I'm not sure if you've looked into the HPFP issue but basically there's a part in the pump which over time can/sometimes develop a hairline crack. This in turn leads to the pump no longer being able to maintain the 5 bar of pressure in the fuel rail. This isn't always the case and can be intermittent more so when the car's cold, all injectors still receive fuel and the car still turns but there is not enough fuel pressure to maintain engine running.
