Wifi .. 2.4ghz or 5?
Different frequencies ;) I think the way that 5ghz transmits it gets less interference, therefore a slightly better speed.
ChrisR
5 will give you less interference as more household stuff uses 2.4 as well, it's a less congested frequency band.
2.4 has better range.
5 is not necessarily quicker than 2.4.
I think.
Don
  182 & LY Clio 220 ed
I think.
I thought 5 was better range (essentially for N rated kit (agn cards)). 2.4 is for the older stuff bg cards.
ChrisR
5 has worse range and worse penetration of objects (i.e. walls).
With signals in general the higher the frequency the shorter the range, or requires more power.
Some N kit has stuff like MIMO which helps boost the range, or I think has more power applied to boost it's range.
