** Part Number Database - Common Requests, Prices + Details **
ANyone got the parts number for 182 rear caliper, passenger side? I couldn't see it listed.
hi everyone i have a 172 sport on a 52 plate just changed discs pads and calipers but have lost one of the rings that sit on the spindle behind the hub assembly i assume its a spacer can anyone tell me the name of the part im looking for and where to get one many thanks
im trying to find part numbers for throttle position sensor for a 2002 clio 172. but the parts database link seems to be broken.
can anyone point me in the right direction please?
Its been off for a while - the only useful thing was the part numbers, prices were from years ago (not had a clio for 2 years). I can put it back up sometime if part numbers are of any use.
Yes please foxy...
I think 99% of people would only need the part numbers. I always take Renault prices with a pinch of salt anyway.
Would be appreciated if you could stick it back up :)
Get another Clio! :P Yeah stick up the part number, be brill mate.
Why am I "forbidden" access to F0xy's database?
I joined just to see this potentially useful resource...
You need to be a paid member to see the guides. Your status shows you as a forum user and you need to be paid up to see guides.
He's on about the website, not the guides section on here. I've not had chance to upload it again yet, its way out of date anyway.
Are you still planning on putting it back up, could use the part numbers as the renault scrappies in shotts up here uses part numbers to request everything from them.
Can anyone help with part nr for both inner wheel arch plastic parts. The car is a Clio 182 2004.
Best regards
​Marcus
Can anyone help me to find part number of my Renault Clio 2006 1.4 Sedan with chasi number VF1EC13166R548434 listed below.
1. Ball Joint
2. Tie Rod Inner
3. Stabilizer (Its a rubber)
4. Shock Absorber
Picture below.
Thank you!
I'm after the part number for the high pressure pas pipe, the pipe that comes from the pump to the rack. Regards josh
Does anyone have the part numbers of the plastic part behind the rear wiper, it's like half a circle. Also need the part number for the plastic triangle bits which the wing mirrors attach to. Thanks.
sorry for bump old threads.
the main link/web foxy create wont work and not available any more .
is there other option to search parts number ?
Clio 182 Trophy Part Numbers
Engine
Oil Filter 8200768913
Sump Plug 7703075348
Sump Plug Washer 110265505R
Spark Plugs 8200239321
Air Filter 8200459852
Auxiliary Belt 8200226493
Auxiliary Belt Kit 7701477519
Cambelt kit 130C12131R
Camshaft sealing Kit 7701471629
Crankshaft Pully 8200386460
Crankshaft Pully Bolt 8200608653
Cambelt Drive Pully 8200251569
Crankshaft Seal (Front) 135109470R
Crankshaft Seal (Rear) 122797403R
Dephaser 8200782671
Alternator (Exchange) 7711134267
Alternator (None exchange) 8200193100
Engine Sump Gasket 8200282199
Fuel Injector 8200207049
Upper Engine Mount 6000073669
Lower Engine Mount (Dog bone) 8200103802
Dip Stick 7700115468
Dip Stick Tube 7700107983
Battery Positive Terminal Cover 7701702362
Coil Pack 8200141149
HT Lead Set 8200334440
Oxygen Sensor 7700107433
Oil Pressure Switch 8200671279
Map Sensor 8200719629
TDC Sensor 8200647554
TDC Sensor Loom 8200673202
Exhaust
Exhaust Mount (Rear) 7700424339
Exhaust Mount (Centre) 7700424341
Exhaust Manifold Gasket 7700114234
Exhaust Manifold Nut 7703034303
Exhaust Clamp (sleeve type) 8200661296
Exhaust Clamp 8200661297
Exhaust Clamp 7701458596
Manifold/Cat Fitting Kit 6000073668
Cooling/Heating
Coolant Expansion Bottle 7701470460
Thermostat and Seal 8200772985
Thermostat Housing 8200934203
Thermostat Housing (Radiator Hose End) 7700869797
Thermostat Housing Gasket 7700104129
Water pump 210107370R
Water Pump Gasket 7700851213
Coolant Temperature Sensor 226306024R
Pollen Filter 8671012063
Radiator (Motrio) 8660000436
Suspension
Sachs Damper Front (NSF) 8200514734
Sachs Damper Front (OSF) 8200514733
Sachs Damper Rear 8200519954 - NO LONGER AVAILABLE
Eibach Spring Front 8200514730 - NO LONGER AVAILABLE
Spring Rear 8200342862 - NO LONGER AVAILABLE
Track rod end (NSF) 7701474492
Track rod end (OSF) 7701474493
Outer Anti Roll Bar Bush 7700784171
Outer ARB clamps 5461 414 05R
Outer ARB Nuts 7703 035 049
Inner Anti Roll Bar Bush 7700847383
Inner ARB clamps 8200 078 548
Inner ARB Nuts 7703 034 235
ARB Bolts 7703 002 918
Steering Column Mount 7701470760
Ball Joint Pinch Bolt 7703002735
Ball Joint Pinch Nut 7703034247
Lower Suspension Arm (Wishbone) (NSF) 8200257956
Lower Suspension Arm (Wishbone) (OSF) 8200257957
Shock Absorber Bolt (Lower) 7703002835
Shock Absorber Nut (Lower) 7703034265
Shock Absorber Top Mount Kit 543A09780R
Shock Absorber Top Mount Spacer Nut 8200867250
Track Rod Kit (Inner) 7701473656
Tie Rod Removal Tool 7711381923
ARB Outer Bracket 700784169 / 546141405R (renumbered)
Genuine Top Mount Kit - 543A09780R x 2
Genuine Top Mount Spacer - 8200867250 x 2
Drivetrain/Transmission
Clutch Kit 7701476557
Clutch Cable 8200699727
Gear selector Bush 7700872205
Gear Selector Bush Circlip 8200328305
Gearbox Diff Seal 7703087148
Gearbox End Cover 7700111166
Gearbox End Cover Seal 8200117602
Gearbox Mount (NS) 8200089697
Gearbox Mount Bolt (NS) 8200689102
Front Wheel Bearing 7701206771
Gearbox Sump Plug 7703075347
Gearbox Sump Plug Washer 7703062062
182 Cup/Trophy driveshaft (OSF) 8200372166
182 Cup/Trophy driveshaft (NSF) 8200372167 - NO LONGER AVAILABLE
Brakes
Front Brake Discs 402069518R
Rear Brake Discs 7701204901
Rear Hub Nut 7703034250
ABS Sensor (NSR) 6000073527 - NO LONGER AVAILABLE
ABS Sensor (OSR) 6000073528 - NO LONGER AVAILABLE
Handbrake Cable (NSR) 8200228347 - NO LONGER AVAILABLE Renault alternative 60 00 073 733
Handbrake Cable (OSR) 8200228260
Interior
Gear Knob 8200822162
Gear Lever Gaitor 8200071449
Carpet Mats 7701207149
Renault Sport Car Mats 7711425548
Hazard Light Switch 8200442723
Rotary Switch 7701051757
A/C control unit 695320015 - Pt Number as of 7/3/19 - 7701051263
Steering wheel airbag squib 77 01 051 757
Instrument Cluster 82 00 261 090
Exterior
Aerial Base 8200282249
Bonnet Switch 7700422637
Boot Catch 8200078950
Fog Light (NSF) 8200002469
Fog Light (OSF) 8200002470
Front Grill 6000073772
Rear Light (NSR) 8200917488
Rear Light (OSR) 8200917487
Indicator Light 8200257684
2.0 16v Badge 8200074475
CLIO Badge 7700849001
Renault Badge 6025306011 - NO LONGER AVAILABLE
Sport Badge 6000068214
Bonnet Slam Panel Seal 8200085033
Windscreen Seal Kit 7701478235
Windscreen Washer Pump 7700430078
Rear Wiper Arm 7701045207
Rear Wiper Arm Blade 7701410155
Front Wiper Arm Blade 8671000035
Bumper Stickers 6000073778
Rear Number Plate Light 7700410754
Wheel Arch Liner Clips 7703077435
Front Wheel Arch Liner (OSF) 6000073748
Front Wheel Arch Liner (NSF) 6000073747
Engine Under Tray 8200158866
Auxiliary Light Cluster (Rear Centre Brake Light) 8200325739A - Pt Number as of 7/3/19 - 7700844706
Door Check Strap 77 00 842 857
'Trophy' Side Sill Decal 8200530349
Head Light Washer Blanks 7701209053 - NO LONGER AVAILABLE
Headlamp (OSF) 77 01 057 659
Headlamp (NSF) 77 01 057 655
Misc
Speedline Corse Turini Wheel (Old Standard Version From Factory) 8200514737 - NO LONGER AVAILABLE (The newer version with the extra raised lettering uses the same part number)
Wheel Centre Caps 8200514740
