Spacers on 2118s?
Car  clio 172 phase 2
Been looking on here for a while now im looking to buy some spacers for the front of my ph2 172 i have speedline 2118s im not sure what size is need.
I seen a ph1 in yellow with white 2118 and his where 25 mm i like the look of that clio so wouldnt mind having the spacers 25mm but will it be any diffrent cus his was a ph1 ?
Are your 2118's et43?
Not the greatest pics, but these are on a 5mm spacer.
i don't think I'd want to run them with a 25mm spacer.
Yeah, Stu had 25mm on the front and 15mm on the rear iirc. I believe that they scrubbed slightly too. Think he's reduced/reducing them slightly now though.
All depends what model of 1*2 you have remember, its not a one fits all situation, they are all different track widths so different spacers needed. Ph1 will get away with the biggest spacers because there narrow.
Theirs also what suspension your using and how low you have it set. Plus how much camber, toe setting and have you cut away the bit of metal near where the bumper and wing joins? All these can have an effect.
Don't want any on the rear as that looks fine IMO . The front is what I want done . They are et38 now scrubbing what's so ever the way it is at the mo . Just want the front wheel to fill the arches a little better.
I'd like to see this too, I run ET43 2118's and got 10mm spacers ready to go on the back, bit concerned as it looks like there's no room at all (172 Cup)
