Temp needle going up then down
  Liquid Yellow 182
My temp needle is taking awhile to go up then starts going down, alo my car is using more fuel then normal. Is it time to change thermostat? What about temp sensor
Amos91
Honorary Member
I'd change the thermostat. Temp sensor normally makes the gauge do some really odd things
Mine would take ages to warm up, sit below half way normally and only get up to half way when giving it some serious stick or in traffic. Got the thermostat changed and it sticks to the middle always once warm.
  DON'T SEND ME PM'S!!
old stat tends to cause quick but smooth changes on the gauge. Faulty sensor tends to make the needle jump
  Clio Sport 172 Ph2
Just change your thermostat. The fact that is it jammed open longer... is the reason your using more fuel as its running richer, as when the temp sensor see's the coolant is colder.... the ECU richens the fuel mixture.
  derv biege barge
I did mine recently thermostat was about twenty quid 5 litres of coolant cost thirteen quid took me hour or so did a full flush.
  Liquid Yellow 182
Lol just phoned renault they said there £27.50 so i said okay reserved it. Thought to my self i will phone eurocarparts, they got exact same one for £15 i said could i have part number and do it online so get discount, they gave it me and ive just got it for £11 with housing, gasket and seals lol. Is it easy to fit?
Amos91
Honorary Member
From what I seem to remember the ECP one isn't that great. Stick with genuine for the thermostat.
Try Adam who works at the Renault Parts Supply Base. Usually cheapest 01902 439264
  derv biege barge
I did research on this site and most seemed to favour the genuine part.
Mine was genuine renault part.
I took airbox out, bottom rad hose off, 3x 10mm bolts on stat housing removed, old stat out, flushed with water, new stat in, 3 bolts in housing, bottom rad hose back on, fill with new type D coolant, run engine up to temp, bleed & top up if needed.
Bleeder is on stat housing and is the only one as far as I'm aware. But that guide is for a 182 not 1.2
Good luck with it.
genuine should be £20.20. Had poor experiences of non genuine so I won't use them anymore.
The_Pirate
  Golf R
I've tried non Renault thermostat's and ECP's and the ECP one simply does not work, put it in and it was pretty ill fitting in the housing, fired it up anyway and the needle pretty much shot up straight away. Bought the genuine Renault one and the needle shot up aswell but it turned out to be a fucked earth strap! Tried both thermostats again and the renault one was fine but the ECP one shot up again!
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Its the seals that tend to be shite (especially with the QH kits). Deffo use a genuine kit but always test the stat in a pan of boiling water before installing it as I've had a couple from Renault in the past two months simply not open.
Mick
  Liquid Yellow 182
So the best bet is just get it from renault? No were else do genuine ones? What about this adam guy at renault parts suply base?
This might be stupid but what should happen if i put it in boiling water?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Without going in to what, why and how a thermostat works... Drop the new stat in some water which covers the unit fully. Bring the water to boil and once the boiling pan water reaches 89 degrees the stat will start to open. When it does pull the stat out and watch it slowly close.
(FUCKTARD WARNING: BOILING WATER IS HOT AND WILL BURN YOUR SKIN, MAKE YOU SWEAR AND GENERALLY BE PRETTY PAINFULL)
If it opens and closes okay it is safe to fit to your car.
Mick
  Liquid Yellow 182
Thanks Mick haha. Is Renault best bet then? Or is there somewere else that does genuine stats? £27.50 seems alot.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Well, Renault SAS don't make them, they're out sourced but the best place to buy one from is your local dealer. The QH stats are actually fine but the seals are just terrible in comparison to the genuine items (they actually measure as thicker) and normally leak after a couple of months.
Stat kit part no: 8200772985 (Comes with seal)
The part retails at £16.83 +vat (£20.20 all done) but we sell the genuine kit for £17. Unfortunatly, by the time you add postage you may as well just get it from your local dealer for a few quid more.
Mick
I've tried non Renault thermostat's and ECP's and the ECP one simply does not work, put it in and it was pretty ill fitting in the housing, fired it up anyway and the needle pretty much shot up straight away. Bought the genuine Renault one and the needle shot up aswell but it turned out to be a f**ked earth strap! Tried both thermostats again and the renault one was fine but the ECP one shot up again!
The ECP one didn't fit in the housing. I had to file the edges down. It's stopped working again so I'm changing it free of charge next time the car comes in to me
  Liquid Yellow 182
So that part number you give me is the one from renault themselves yea? Is that with housing and gasket? Or stat on its own?
How much postage do you add on then mate? So £17 +?
  Liquid Yellow 182
Sorry Mick its been a long day mate, been at hospital all day and s**t. Im not usually this slow lol. My local renault in Coventry want £27.50 for stat, gasket and seals. Is that right? That part num you gave me is it to quote at my renault or for your shop lol
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Thats the part number for a genuine renault stat kit (x1 thermostat, x1 seal).
£27!!! Hoky fek, I need to up my prices. By the time I've packaged and shipped it, its gonna be close on £23
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Right, STOP!
I'm currently working on your car being a 2.0 RS... I'm now guessing thats not the case?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
It means it will still be £23 but thats without delivery I'm afraid.
