Ok so i remove my rear badges and diamonds going to spray them white, once done what can i use to stick the badges back on the car?
Obviously something that won't damage the paintwork!!
Best method to remove badges is to heat them up with a hairdryer or heat gun (not too close!) which will soften the double sided tape they are stuck on with, and then use a bit of fishing line to remove the badge from the body.
Get some 3M double sided automotive tape to stick the badges back on, just it will be a little fiddly to cut the tape to match the lettering...
