oil breather tank (need set-up help)
ive been told to put another filter on the return spout? or should i just return it into the air intake hose?
Ive never rigged one up, never needed to, but id assume you just fit it inline with your breather, im sure someone who uses one can confirm
Either vent back to inlet or atmosphere using a filter, what do you need help with?
if i should vent back into intake pipe or buy another filter for return spout?
if the can comes with a filter on top, whats the purpose of the return hose if it gets vented out the filter on the can? is it maybe to keep the pressure the same or somthing??
this is still not very clear to me.
should i just splice the breather pipe and put 1 end to the in on the can and the other end back to the air intake from the return?
