The only other way is to leave the nut on but at the end and get a 13mm and 17mm spanner and place the 17mm spanner on the arm at the end of the nut and undo the nut with the 13mm spanner and sometimes it pops it off but I've tried this twice with 2 clio's but the were to seized on. I used a hacksaw in the end
Rear Wiper Arm removal on 2010 Model, I took the kids to local safari park and stupidly drove through the monkey enclosure resulting in a rear wiper arm being stolen, all that's left is the small plastic piece which the arm clicks onto although this will have to come off as it has a snapped edge, I have got the plastic circle out and removed the bolt from underneath, do I need to remove anything from under the plastic trim inside the boot as tried pulling it off and not budging, I don't want to damage the motor
