So, I broke my 200. Pics inside.
Car  Golf 7.5R & Clio 200
As per title. 200 is broken. No where open over easter to fix.
I have a trolley jack and some stands, no idea what to do apart from just try and push it back.
Thoughts?
ImageUploadedByTapatalk1364500304.805252.webpImageUploadedByTapatalk1364500313.566891.webp
Undo the clamp, 2 x bolts. Seal it up and slide it together and tighten, should be all good then. Just make sure it's all square etc.
May call the RAC - its dark and cold. I guess they could fix it.
Any idea what could cause this to just flop out? Just wear and tear?
May not of been tightened up properly, that ain't how it left the factory though, exhaust must of been chopped at some point. Yeah, AA / RAC would sort it for you.
When i took it to 519 for a service Dan said it looked like it had a new back box on it, said it looked like a renault one though. Will get the RAC out then, will update soon!
Bet it's had an aftermarket system on it in a previous life!
That looks like the silencer has been removed. Does your car sound quite raspy/crackly?
silencer removal is a very popular mod with the mk3 lads
Yeah the silencer has been removed, I had that done a little while ago.
RAC bloke came, weirdest man alive, popped it back in then told me to get it fixed properly with some 'gumgum'.. Right odd hall he was.
Doesnt sound as beefy now lol
Never had any luck with Clio exhausts ever. The meganes however, never an issue, the coupe is still on the original 11 year old one!
Every Clio i've had it has broke. Every time.
I actually think i had the 182 in at C&C around 9 times for repair/adjustment! What a fvcking mare!
He's probably right as they're a solid section from factory and the process for replacing the £700 rear silencer (I LOL'd hard when I saw that price) is to cut the pipe and sleeve it, as pictured in the OP's first post.
There's a similar sleeve kit avaikable for the Laguna II/Vel Satis 2.0 Turbo which is longer and grips better but I think the OD will be different.
Get it welded - problem solved.
Ah, sorry to point out the obvious :o didn't realise you had it done
Lmao he sounds hilarious
Most oe back boxes come in repair section form or you'd be replacing to cat always.
Same happened to me on my 182, middle pipe and sports cat come apart! never heard anything so loud in my life! happened about 15 miles from my house at 11pm! Easy fix, either do it yourself or take it to an exhaust place and they will do it in 5 minutes.
My clio backbox jumped ship one night on me after about 1k miles, my old meganes centre silencer opened itself up like one of them polystyrene kebab boxes, remained attached on one edge, you could open and close it lol
If you look through your reciepts it had a new exhaust at Renault London West. ( IIRC )
Therefor if Renault London west or East should refix that FOC.
S
S
Bought a new clamp from renault for £25.72 inc Vat, borrowed a friends ramp and he had some exhaust paste, job done. Looked like the clamp used previously was broekn a long time ago, the screws thread had worn away haha!
​all done now though :)
Ry should of popped over to see me mate I would of sorted if for you! ;) glad it's all sorted!
Chris @ DetailMe
