Tighten My Nuts
Said already but I'll say it again as I think it's the single most important factor in getting good mpg, and that is, look ahead, plan, and BRAKE LESS.
Holding a constant speed uses very little fuel (unless you're sat at 70mph+), it is accelerating that burns it up, and every time you press that brake pedal, you need to accelerate again to build your speed back up.
Time your approach to roundabouts so you can keep rolling and slip into a gap (plan to stop but look to go), ease off the throttle way before you need to turn off into a side road so you can coast down and not brake, leave double or even triple your normal distance to the car in front so you can sit there rolling along in top while those bunched up ahead are continually braking/accelerating/braking/accelerating.
Driving like that I saw an average reading over a full tank in my 200 of 43mpg so it definitely works!
