As can be seen I'm struggling with the 120mm trumpets in my ph1.
Any way of making them work?
Will they work with the filter hitting the underside of the bonnet? Or am I best to go down to 90mm trumpets?
Don't like that idea lol.
Getting some 90s at the weekebd
I will be changing the filter, but I can't find a 100mm sausage one? Biggest I could see was 65mm which suite the 90mms.
Think I will be taking them mate unless someone has some inside knowledge.
you prob wont like this idea, however you could always cut the trumpet and use 90 degree samco hoses to angle the filters down then use individual cone filters??
Are you selling the 120s?
Mount it using the front crossmember and the mounting points on the front of rad. run a strip of metal between each point using drill and bolts then drill thru the crossmember parallel with the strips you have made then run 1 larger bolt thru each strip and thru the crossmember, then put the nuts on tighten them up and away you go.
polo rad all i've done is used the rubber feet at the bottom and used a small bent piece of ally plate and used self tapper nut in 2 the cross member and rad, don't want it solid mounted with all metal brackets as the vibration will cause the rad 2 crack... give me 5 mins i'l see if i can get some pics of how mines mounted
Fair point, no reason that shouldn't work just as well.
Could of told you they wouldn't fit. 90s are a squeeze on a ph1 bonnet with a decent filter, let a lone 120s. Swoops down lower than the Ph2
just simpler mate, i have seen the way you mentioned but they hadn't used and rubber grommets anywhere hence why i mentioned the cracking etc which is what put me off about it soon as i saw it
It's fine should sell the 120s for more than getting a set of 90s!
My 90's just got that bit more expensive![]()
