As some of you will know I recently replaced my engine, fine no problem...
Now I have replaced the gearbox using the exact same technique...
Now here comes the problem: I have a fault where my lights work fine when on side lights, then when I switch them on to main beam the indicator comes on instead of the main beam bulb on the drivers side....
This gets weirder now because when you indicate on main beam the main beam bulb flashes unless you have the lights turned to sidelights o off.....
I have checked and cleaned all the earths/earthing points and checked to make sure that the wires are all in the correct place/orientation.... All fuses are present and okay, all bulbs are also present and okay.....
Any ideas? My guess is wiring loom but I wanted to make sure there was nothing else amiss.....
Thanks guys any help/advice will be appreciated as always!!!
