several issues... any advice?
Car  RS clio 172
Hi all,
Been looking through the forum on the same issues I've solved one! but have a few others...
1. When taking a hard corner (long one say a motorway turn off) the STOP, battery / oil light will flash constantly until on a straight again. This only happens on a hard turn not normal corners. Would this just be low ish oil on either the brake fluid sensor or engine oil moving about?
2. When starting the car sometimes it turns over in a second but sometimes it really tries and takes at least 3-5 seconds and once its done the trip counter for mpg/miles done would have reset. would this be starter or battery issues?
3. When the engine is on it has a light squeel / belt noise until warm but i can hear it whistle a bit under hard acceleration sometimes, would this be a tight or worm aux belt atall?
Apologies for all the questions but saves making several threads ;)
​Thanks!
Check the brake fluid level
The 2nd i would say possibly battery. Get it checked
3rd i'd say aux belt is worn
If the alternator is shot flicking lights are a sign
Brake fluid level is low for the 1st issue
Thanks Kyle!
Very fast reply ha, aux belt is the cheaper of the belts for replacement and labour right?
Yea aux belt is the cheapest
Are your headlights flickering?
Never really noitced, mainly daytime driving really and only owned the car over a month so been staying light later than usual.
If I start the car and leave it idle would they flicker a lot or would this be intermittent flickering when driving? (172 xenon lights)
The interior light would flicker. Have a look at the headlights also
If the brake fluid is low. Stop & handbrake light would flash up
Thanks i'll have a check tomorrow :)
+ yeah the handbrake one and stop flashes at me when hard cornering only. for some reason I put oil light in my first post.... haha
Benz, did your headlights flicker?
i've got a similar problem, all lights flicker on idle. Kyle, are you saying the aux belt can cause this?
