Suspension gurus what do you think of these readings?
497adam
Car  clio 172 phase 2
ImageUploadedByTapatalk1375365755.448440.webpImageUploadedByTapatalk1375365765.274705.webp
After getting fed up of a slight pull to the left went the Clio checked on Hunter alignment machine. They very slightly adjusted toe but the only thing they could put slight pull down to was cross caster? Or possibly tyres. What are your thoughts. It is slightly better since toe adjustment but still there
Sorry to Hijack.
I've just had the exact same done and would like the same. So could compare mine to yours and what not.
Also a little dead around straight ahead. Up to know Birchdown have replaced shockers , springs , wishbones and top mounts
Ktec coilovers, 25mm spacers, cup w/b's and 5mm spacers on the rear.
I seem to have more toe on the rear than the front?? :(
Swap tyres from front to rear making sure there are a matching pair on both axles. Are you sure its not just the camber of the road pulling you to the kerb?
Sorry to Hijack.
Your car looks like its taken a knock to the right rear as it has positive camber and 1/4 of a degree more toe in on the right rear. Does your car sit a good height, slight nose down, shocks in good condition, track rods, rod ends and so on.
could well be tyres, sounds silly but i changed mine, old tyres alignment was fine, new tyres with different tread pattern = alignment off. one of the guys who works for mark fish said exactly the same.
New-ish track rod. New wishbones, need to enquire about new track rods, do you know how much they are?? And what size 330mm??
The suspension seemed fine when I had it off a lad on here but started causing some major knocking. So thinking of going cup shocks and cooksports?
something looks funny with the back end of your car, heres my most recent one, you will notice my front drivers hub is bent and had to be corrected with a camber bolt until I get a new one ordered, also my caster is out as im running cup arms
Yeah something isn't right? Could it be the 5mm spacers I've fitted to the rear? Might just by a new beam and see where I go from there tbh.
It's actually f**king me off ATM.
Thanks Fred that's what I was getting at , better get some disks ordered
All other readings look normal ish for a standard ( other than pro lines) clio?
Going to try in a bit didn't get chance yesterday , will try and check the bearings too
Swapped tyres front to back , still the same. Also "serv" and traction lights are now on any ideas?
Pretty sure I didn't knock the speed sensors or anything just swapping wheels
Could spinning the wheels while up on the jack upset things? Didn't have the ignition on although keys where in
If bearings were knackered enough to create those camber readings would it be obvious when I tried to find any play? Because I couldn't find any
Yes. Did you have the car jacked up, hands on outer edge of wheel and try to wobble it in and out?
