I believe you have to get a phono converter to change the output from the standard headunit.
If your amp has high level input you should be able to tap into the rear speaker wires and run to amp off them. if not danward's suggestion would work.
^^ I patched right input from right rear speaker, and left input from left rear speaker
Works a treat!
