Can someone take a picture of their wipers?
  Suzuki Ignis Sport
Who has bosch aerotwin wipers, as I'm still not convinced my wiper arms are in the correct place. Just want to to see the final position of the wiper arms, how far down they are. Cheers!
  Suzuki Ignis Sport
Nope, my wipers are whistling. Never had a problem with whistling wipers before I took my wiper arms off to do the washer pump. Not sure where they're meant to officially sit.
  Fiesta ST2 MP215
how odd, have you just not closed the clip down properly? that holds the arm in place, I'd say it's more likely that, even when mine stopped a while ago they were sitting half way up and didn't whistle.
  Suzuki Ignis Sport
The clips definitely closed properly, suppose it could be a dodgy batch of Aerotwins though I suppose. Just wanted to make sure the wipers are sitting where they're meant to be :)
  Fiesta ST2 MP215
it does sound odd dude, does one of the blade not protrude too far out to one side at all? take them back and try another pair.
if they didn't do it before and you never had the wipers off then it has to be them, no reason why the arms would be out of place.
  Suzuki Ignis Sport
Nope, they look fine. I took the wiper arms off, not just the blade when I did the washer pump. They never did it before I took it off, this is why I think the arms in wrong place slightly :p
Flat Eric
Sing Hosanna!!
  F31 35d, Skoda Yeti
If you want any other angles let me know
  Suzuki Ignis Sport
An above angle with both the wipers in shot, its the other one that whistles haha! What have you got on your scuttle panel trim? Looks brand new!
Flat Eric
Sing Hosanna!!
  F31 35d, Skoda Yeti
I'll get another pic in a bit then
Erm there's no product on it at all. Just snow foam, shampoo and a mitt I guess?
No plastic restorer products
I guess it does look new, although the caps for the wiper arm nuts are looking dated :(
  Suzuki Ignis Sport
Cheers! My trims all white and faded :( Haha, swap your scuttle panel for my caps ;)
  Suzuki Ignis Sport
Yours are higher up than mine anyway, so must be the actual catches on the wipers. Took wipers off and put a MF under the arm and the whistling stopped. The passenger side scuttle panel is lifted little for some reason, so ive taped it up :)
Cheers for pics mate!
Flat Eric
Sing Hosanna!!
  F31 35d, Skoda Yeti
No probs mate. Ye my scuttle panel is raised slightly either end I think.
I'd try another set of wipers if you can.
These are great wipers though :)
