An exhaust will make very little difference to torque levels on a standard NA engine. It will be more placebo than anything.
To get relatively decent (in NA terms) levels of torque you'll need some wilder cams, ITB's with good length trumpets, or something akin to that. You'll also need deep pockets.
Best way to get torque, sell Clio, buy diesel.
Here we go again
Do you want the meaningless book value, given that these engines seem to have such wide variances from the factory?Does anybody have the actual bhp not ps and lbs/ft figures for the two standard engines?
182 exhaust manifold gives you more mid range torque.
I went from standard 172 with 173bhp/145lb/ft to same car with 182 manifold, decat, matched inlets, itg panel filter, samco bend and k-tec stealth and ended up with 188bhp/159lb/ft
I know I am not going to be looking at big torque figures but I'm just wondering what are the best mods for torque?
Is a 172 exhaust or 182 exhaust better for this?
You want torque from an exhaust and an induction kit? yep, here we go again indeed.
169 and 179
standard figures rarely happen
What budget do you have to play with?
I understand the average standard 172 would produce about 160bhp at this time in it's life?
Ive only seen them do 200 when making torque in the 140s tbh. For torque of 155 you will need it timed differently (and ideally standard cams) and then you will be back down more like 190.Rs2 and 197 cams
200bhp max power and a linear 155ftlb across the rev range
I bloody well hope not or I'll have to make a 160 cup badge.
Ps. Best torque I've seen without itbs or boost from an independent test at Surrey is millerins cup.
182bhp and 165lbft. Standard inlet, decat, exhaust, pops and bangs map.
Just a freak of an engine. I can't explain why it did those numbers!
I'd ask them what they think back pressure is and why a 4 stroke wants it?I wish! Someone told me de-catting an N/A engine hinders the back pressure, is this true?
Back pressure is just needed to eliminate lag isn't it? Turbo or SC'd only. Get a decent decat and straight through pipe none of this baffled crap. Mwm have some good prices on rs2 and cams etc if you've got deep pockets thats whered id go rather than itbs.
If they can answer the first bit they are certainly going to struggle on the second!
flol.
You do not want back pressure on any 4 stroke, unless it's caused by a turbo!
Back pressure is always bad for all 4 stroke engines but on a turbo you have no choice but to have some as the turbo relies on a pressure differential before and after it.
Gas speed increase from a smaller exhaust pipe is good for low down torque on an n/a engine. But that's about generating negative back pressure at the end of the exhaust stroke. It's not about having positive back pressure. That's always a bad thing.
Porting is ok, but for the money, such as needing the belts etc done at the same time, you might as well chuck cams and a remap in there, you'll be looking at over a grand for the job, RS2 seems the way forward with this.
Porting won't be as effective as an RS2 either.
Best N/A torque will come from cams, ITBs, headwork (port/polish), 182 manifold and a straight through exhaust.
Mine is 184bhp and 173lb/ft on the Dyno Dynamics rollers at RS Tuning, that's with Piper cams, headwork, ported inlet, 182 manifold, sports cat and KTec exhaust.
Another car of similar spec (I'm not sure if they ran a sport cat or decat and what exhaust but the same mods otherwise) on the same rollers ran 186.6bhp and 173lb/ft.
Agreed but I don't think the OP is wanting to fork out thousands for a bit of torque though. I think an RS2 can be had for Sub 2K, ITB's alone without a map is over 2K.
They are some decent figures! I'd like that chunk of torque plus RS Tuning are very close to where I live
Its a lot of expense and generally you will lose a bit of fuel economy and you cant have cruise control etc either.Exactly that, won't be going down the ITB's route no matter how appealing they are
Rs2 and 197 cams
197 cams will drop mid range torque vs standard in conjunction with RS2
Chip-mk1 said:Ive only seen them do 200 when making torque in the 140s tbh. For torque of 155 you will need it timed differently (and ideally standard cams) and then you will be back down more like 190.
flol.
