Whose Clio is this?
The_Pirate
  Golf R
Anyone know the spec?
Tim.
There's every chance they took the picture then flipped it so everything appears backwards.
I've seen them do it in mainstream car ads to make the car appear LHD when it was RHD. They use pallendromic (sp?) number plates as well, or ones which read similar when flipped - 0X0 MVT, for example.
Good shout!
edit:
Yep, flipped! Stick is now right, but no steering wheel o.0
f**k knows what theyve done.
Tim.
That's fine with the fire engine because the letters are huge, and it's likely to be approaching you from behind.
The chances of reading the CS sticker once it's gone past you, given you're both doing 10mph, is minimal. Both you and the Clio doing 30mph and the chances are zero.
There must be more to it.
cat171
What does this say, looking at it? And then what does it say reversed (i.e. when it's behind you and you're looking in your mirrors)? C'mon Craigy boy ;)
Derr, I get it bro!!! :p
I just don't get the 'scene'
I like it on Jap cars though when they do the graphics backwards on one side.
  182/RS2/ Turbo/Mk1
If you see it go past and look in your mirrors, you'll be able to read the sticker. Is my guess.
If its gone past in the opposite direction you mean? Ie if its oncoming traffic?
You'd need some seriously good eyesight for that, as it would be fecking miles away by then.
More like its just yet another attempt to be pointlessly "different" in an utterly worthless way.
20/20 vision ;) But agreed.
karol_SVK
  PB172,XC70_2.5T
it is not mirrored, as the seats say sparco:).
I would say some member just put him a sticker on the back window and was not the owner.
