172 Gearbox Problem
Car  Monaco 172
My gearbox has crapped itself, or so I have been told by the garage.
Just wanted to check on here before I fork out for a replacement to be fitted if this is truely the issue. Horrible vibration noise under revs, although its fine in reverse. No noises though if decelerating whilst in gear and all gear changes are smooth as ever. Box is only on 37k.
Any help on the issue before I pay out of the nose for it?
Paddy
Just had the quote come through at £980
Second hand gearbox £100-£200, a decent mechanics time no more then £300,
when my gearbox shredded itself at 70 mph, £500 got me a replacement box fitted by a respected garage who is a member on here.
That's if it's actually the gearbox, they normally don't slot into every gear perfectly if they're f*cked.
Its gone in to a trusted family mechanic. He seems to think it might be a mount but won't get a proper look at it until Monday. Fingers crossed.
I brought a spare gearbox off eBay £50 just incase mine go's again mine was was £600 rebuilt and fitted as it messed up the gears and wouldn't drive
Turns out it was the mount that is located under the battery? Much cheaper job to do but apparently no renault garages stock the part needed so may be a bit of a wait for that.
Its the bolt and two nuts as far as I could tell from our mechanic, can't really offer much more of an explanation than that.
Generally the casing breaks before the mount, well that's what happened to mine so had to get a new battery/mount casing.
